UFACTORY XARM
A multi-axis robot perfectly
balances power and size
Ideal for:
○  Machine Tending
○  Bin Picking
○  Mobile platform
○  Lab Automation
○  Robotic Research
US$5,299.00US$5,494.00
Performance
Payload
Payload
5 kg
Degrees of freedom
DoF
6
Reach
Reach
700mm
Weight
Weight
12.5 kg
BRIEF INTRODUCTION
Durable Collaborative
robots for your automation
  • Industrial-grade harmonic drive and servomotors guarantee 24/7 working without stop.
  • Crafted from Carbon fiber, 15kg weight makes it possible for easier deployment.
xArm11
xArm Collision Detection
Flexible deployment with
safe feature
  • Hand teaching, lightweight, space-saving and easy to re-deploy to multiple applications without changing your production layout.Perfectly for recurrent tasks.
  • Collision detection is available for all of our cobots. Your safety is always the top priority.
Graphical interface for
beginner-friendly programming
  • Compatible with various of operation systems, including macOS and Windows.
  • Web-based technology compatible with all major browsers.
  • Drag and drop to create your code in minutes.
Powerful and open source
SDK at your fingertips
  • Fully functional open-source Python/C++ SDK provides more flexible programming.
  • ROS/ROS2 packages are ready-to-go.
  • Example codes help you to deploy the robotic arm smoothly.
Powerful and open source SDK at your fingertips
Open source SDKs
xarm acc
Seamless integration with
official accessories
Our robot arm can equip with a range of accessories to easily achieve the application you need.
  • Gripper
  • Vacuum Gripper
  • BIO Gripper G2
  • 6 Axis Force Torque Sensor
  • Linear motor
Beginner-friendly
Support
Support
​Dedicated online support to figure out the proper way to run the robot.
Realtime Chat
Realtime Chat
Realtime chat support on you laptop or mobile phone.
Plug & Play
Plug & Play
Plug-and-play. Unbox, set-up, calibrate. No technician needed.
1 year warranty
Warranty
1 year warranty
Minimum 15000 hours of full-time use
SPECS
Working Range
Working space of xArm series (unit: mm)
Note: The following working range diagrams are only for safety assessment.
xArm Working Range
Working Range
Dimension
Robot tool head
xArm end flange
Robot base mounting (mm)
xArm robot base
Comparison
xArm 5 xArm 6 xArm 7
Payload 3kg 5kg 3.5kg
Reach 700mm 700mm 700mm
Degrees of freedom 5 6 7
Repeatability ±0.1mm ±0.1mm ±0.1mm
Maximum Speed 1m/s 1m/s 1m/s
Weight(robot arm only) 11.3kg 12.5kg 14.3kg
Maximum Speed 180°/s 180°/s 180°/s
Joint 1 ±360° ±360° ±360°
Joint 2 -117° ~ 116° -117°~116° -117°~116°
Joint 3 -219°~10° -219°~10° ±360°
Joint 4 -97°~180° ±360° -6°~225°
Joint 5 ±360° -97°~180° ±360°
Joint 6 ±360° -97°~180°
Joint 7 ±360°
Hardware
xArm Robot Specs
*Ambient Temperature Range 0-50℃
Power Consumption Typical 200 W, Max 500 W
Input Power Supply 24V DC,20.8A
Footprint Ø 126 mm
Materials Aluminum, Carbon Fiber
Base Connector Type M5*5
ISO Class Cleanroom 5
Robot Mounting Any
End Effector Communication Protocol Modbus RTU(rs485)
End Effector I/O 2*DI/2*DO/2*AI/1*RS485
Communication Mode Ethernet
UFACTORY xArm AC Control Box UFACTORY xArm DC Control Box
Input 100-240VAC 50/60Hz 24-72VDC
Output 24VDC 20.8A 24VDC 672Wmax
Weight 3.9kg 2.6kg
Dimension(L*W*H) 285*135*101mm 262*160*76mm
Control Box IO CI*8+DI*8
(Digital Input)
CO*8+DO*8
(Digital Output)
2*AI
(Analog Input)
2*AO
(Analog Output)
Communication Mode Ethernet, RS485 Master*1
The control box is included in default.
Compatibility
Interface
Windows 10, macOS 10.10 or later, Ubuntu 12.04 or later.
API Compatibility
Interfaces with any product that has an API
Our robot API is open-source and users can make adjustments to the software as needed to interface with other products. While all integrations are possible, they all require custom code work i.e. most customers will need to write custom libraries and install software packages that are not shipped with the robot.
Open-source APIs GitHub.
Learn more
Hardware Compatibility
12~24V general purpose inputs/outputs
ModBus RTU (RS485)
Software
UFACTORY Studio is a web-based software running inside the control box, which means no additional installation needed before running the robot. Any computer with a browser has the access after 1 minute hardware connection.
xarm Studio
Service & Support
Warranty
1-year warranty against manufacturing defects.
Stress-tested for at least 15,000 hours of full-time operation.
Certificates
Certifications complete (CE)
Demo videos
Q&A
How long is the lead time?
The lead time of xArm robot is 2-4 weeks.
From US$5,299
